Rear door handles dont work...
2007 Jeep Wrangler jk. Wondering if anyone has had this issue and knows how to fix it. When I press the door handle button from the outside of the jeep or won't open the door. I took the plastic door panel off and the door handle off as well. I can manually push my finger into the whole and press the flap down to open the door but when installing the handle it's as if the metal rod connected to the handle button doesn't extend far enough to open the door... u can open the door from the inside no problem. Also this problem started after rubbing against a rock wheeling. Than about 5 months later I rubbed against a tree now both rear door handles don't work...
Are the door locks actuating. Do you have electric locks? If so check that the wiring harness is plugged in properly.
Sounds to me like a door lock issue due to the fact the inside handles work properly.
They are not electric locks. And it's the rear door. With the door handle off the jeep of i stick my finger in the hole there is a metal flap that's supposed to get pushed by the rod from the outside door handle. But it's as if the rod isn't long enough to push the flap down far enough to open the door.
does appear like that's the problem, I also bought new door handles just to make sure. I took the door panel off and such but I didn't take off the inner door panel where the mirror track is and such I might do that and try to see what happened that way. "Annoying" I'm surprised I can't find any info on this happening to anyone else on here with manual locks etc lol
Meant to say "doesn't" and I dono why the hay this app won't let me upload photos
