Rear brake leak?
That looks more like a rear axle seal leaking than the brakes. I've not been into my rear axle too far so I can't give you further direction on where to look.
Both my buddy and I had gears installed and he had a front axle seal leak as well. The shop took care of his so now I'll call them tomorrow to see if they'll take care of mine too! I don't think it's a coincidence.
my rear seal started leaking
yesterday i saw this , made a appointment for next week . it seems pretty rampid
on jeeps lately . mine never sees abuse so its obviously poor quality seals they use
its warranty work but still not what you like to see . I replaced rotors and em brake kit and it has diff fluid all on it now . im not sure if they will need to be replaced now all gummed up with grease , on em brake pads - 35,000 miles on my jeep.
Yould have to remove tire , remove caliper, 16mm bolts pull off the rotor /drum. and look behind your emergency brake assembly youl most likely see it coming out around there, on to back plate its not a easy fix , dealers say a few hours at least the axle will need to come out and things cut to even get at the seal.
Mojo- I abuse and have 122k miles....No leaks. I don't think it's "poor quality" from the factory, potentially linked more to debris and/ or overfilled diffs.
I just made the appointment to have the seal replaced. Turns out that the axle seals are part of the 5year 100k drivetrain warranty just incase no one knew. Thanks
My 12 passenger rear began leaking at 24k. I'm anal and clean and wax the inside of my wheels and started noticing a greasy film. Took it to the dealer early on and because it was so clean they said there was no problem. Progressively got worse and finally on a rainy day you could really see oil on the inside of the rim so I went straight there. They replaced it under warranty but by then my pads were shot. They cleaned everything but wanted to charge me to replace pads. No way was I paying! I ended up doing them myself.
Former Member
my rear axle isnt over filled but
i wouldnt say it dosent see road salt , its weeping out . slow right now
hope to get it fixed tuesday
