Rear brake froze up?
Former Member
By the way...don't ever count on a P-brake working as an E-brake as most people call it
You'll end up on a web video that will be around for a thousand years
X2 most often missed routine is thoroughly cleaning and lubing the slides. Next I would think frozen P-brake especially if it is hardly ever used.
It is kind of funny when this stuff happens with the jeep, I get all pissed that it happens.
Ripp the jeep apart, swear, buy a few new tools or parts, swear,....check the forum for help,.... Fix it and say "that was pretty cool, I learned something new about the jeep"
Yes, you're right on learning something new. Lesson 1, troubleshooting at night, bad idea. Working on hot brakes, bad idea. Taking a deep breath and waiting for awhile, good idea. As was said, jack it up, take the wheel off, try turning the hub, eliminate each suggested item one by one. My bet, a frozen caliper. You may now need a new rotor (overheated/warped) OR new e brake shoes, and/or new brake pads. Regardless of what you find and replace, be sure you clean and lube the pad slides. Did you replace the little shiny slides? Did you use OEM pads? I put a brake thread on the forum awhile back. The little shiny sliders have a small difference and should be installed the way they were removed. If you didn't get new ones, the old ones can be reused. I'll try and send the thread. Good luck.
My money is on a sticking caliper. I've had it happen on 4 different occasions, and each time the caliper never totally froze up. After leaving the Jeep sit for a while, it would be fine.
In the last month, I've replaced all 4 calipers, hoses, pads, and rotors.
Spent less then $55 for caliper, brake cleaner spray, grease, and brake fluid. Job is done!
Bleeding brake line
Hi All..I just had my back right caliper freeze up on me after a brake pad change. My question is, when replacing the caliper and bleeding the brake line, do you have to bleed all four tire's brake lines, or only the caliper you're replacing?
