Ready for the Canadian winter...........
Hard Top on..........check!
3 stage Wax..........check!
Slush mats in.........check!
Krown Oil Spray applied...........check!
only piece missing is a good set of tires which will have to wait until next summer...thank god for 4 wheel drive
Yup - hard top went back on a few weeks ago. Nice having that wiper back there again. Oil change and fluids done. Will pull out the block heater cord soon too.
Originally Posted by Cdyspeed
Just wondering what's the oil spray for?
Edit: And also are the block heaters expensive for these things
Don't know about the oil spray, and most of the jeeps up here come with the block heaters, so I wouldn't know if it is expensive or not. At least if you are north of Vancouver, that is.
The block heaters are about $50. The expensive part might be the installation. A battery blanket would be a good idea too. They are about $30. I just hooked up both items to a 3 into 1 plug end and ran a single cord out thru the grille. The snow tires will be going on soon. And I have to drain the summer washer fluid and replace it with the winter stuff. I'm in northern Manitoba, Canada. I have a 2011 Sahara Unlimited, 100% stock for now. It is my 3rd Jeep product and I love it.
They are nice to have below those temps and definitely easier on your engine starting on cold morning.
Edit: If you are going to use a block heater... Make sure you tie the cord around a solid brace under the hood then bring out the cord between the grill and the hood. That way when you forget to unplug it and back away from your spot it won't pull the cord out of the block or rip your grill apart.
