Rattle in door pillar
Old 08-06-2009, 07:45 PM
  #261
Matador's Avatar
There is a TSB for the rattle in the door pillar.....the dealer will apply a special grease and problem solved......it comes back but they jsut have to re-apply the grease. Lasts about a yr.
Old 08-07-2009, 04:09 AM
  #262
Evil Bunny's Avatar
UPDATE: The rattle that was next to my left ear every time I hit a bump is now gone. Thanks to the electrical-tape-on-the-striker fix.
Add me to the list of believers!
And it only takes about 3 inches of tape. I stretched mine a little bit as I was wrapping so it fit properly (unstretched it is a tight fit). It is also unnecessary to wrap the entire striker. Like has been said, you only need to wrap the side that is facing you when you open the door.
Old 08-08-2009, 07:51 PM
  #263
bradj1964's Avatar
Mine has the clunk noise too, im gonna try the electrical tape trick too!!
Old 08-09-2009, 09:01 AM
  #264
saharastyle1354's Avatar
the guy who always works on my jeep at the dealer solved that for me, he noticed it while taking it on a test drive for clunky steering, and put some electrical tape behind the panel for me to get rid of the clunk..guy is the man, its nice to have someone like that at a dealership!
Old 08-09-2009, 12:06 PM
  #265
bradj1964's Avatar
Drove the jeep today over some bumpy country roads no more clunk!!
Old 08-10-2009, 09:40 AM
  #266
Tight_wad's Avatar
3 inches of black tape rapped on the striker and my noise is history!
Old 08-10-2009, 10:35 AM
  #267
db09JKU's Avatar
Electrical tape fixed mine this weekend. Took longer to get the tape and scissors (I wanted a nice straight clean cut), than it did to do it. No clunks in my ear anymore.
I wonder, might be in here or in one of the other threads, but if you take the hinge bolts out to remove the doors and don't install them back, if that allows just enough movement for the doors to make the noise?
If so, if not, doesn't matter, I'm leaving the bolts out, it is quicker, easier than putting the bolts in and seeing if that is or is not the case.
Old 08-14-2009, 11:17 AM
  #268
roadking54's Avatar
.....well, here's my "clunk" noise contribution just like the others. I've got it. Buying electrical tape tonight. Thank you forum!
Old 08-14-2009, 06:45 PM
  #269
CreepJeep67's Avatar
You can also put some white lithium grease on the latch
Old 09-11-2009, 01:22 PM
  #270
montano's Avatar
Default Once again
OK I've had the driver side door latch greased by the dealer and the problem was still there. I then took it in and had the latch replaced and the problem went away. Now it's been about six months and the clunking noise is back on the driver side. Has anyone else had the same problem with a replacement latch?
Quick Reply: Rattle in door pillar
