Rattle in door pillar
#112
After reading through this thread, I see some have a rattle and some have a thunk. I had a rattle high in the B pillar that I narrowed down to the zipper pulls from the rollbar padding. The noise was coming from both sides. I simply tucked the ends back under the padding to hold them tight and now all is quite for the most part. (Usual soft top noises) I haven't had the thunk yet. Don't know if this will help any rattlers out there but might be worth looking at.
#115
Well, I put electrical tape on all 4 doors and magical no more thunk noise it is so much better driving. Please let me know about the took coating I hope that will be a more permanent fix and look much better.
#118
rattle
I have the same problem. It does get annoying. I will have to check some of the things you all have mentioned. I also have a similar sound coming from the rear of my jk. any ideas on that?
#119
Well I have not had the door rattle yet but i did have the back ratttle. the fix is funny. Below the door latch on the jeep there is a black bracket that acts as a guide for the door. i think the rattle comes from fricton on that peice. I Greassed it with some Vasiline and have not heard the rattle since.
#120
No new latch for '07 !!!!
WARNING!!!
For everyone with an '07 there is NO UPDATED DOOR LATCH to solve your clunking door problem. My dealer finally installed the "updated latches" after trying everything else and several unsatisfying visits. I supplied the part #s that are posted in many threads here and they ordered and installed them without double-checking with Chrysler. These latches only work on '08's. If installed on an '07 the power locks will not work. Chrysler sent a notice to dealers instructing them not to install the latches in '07's due to the incompatibility.
If you have an '07 get some electrical tape. Chrysler has not acknowledged the problem even though there are thousands of us with a clunk in our ear every time we hit a bump.
