Rattle/ Clicking sound Need help!
I've noticed this sounds for a few days now, it only happens when I'm going over the insane speed bumps in my apt complex and sudden drops in the street (sukken man hope covers). I'm taking it into the stealership to have it checked out under warrenty while I still have it. Any one else have this prob? My Jeep is pretty much stock, factory wheels and suspinsion. the olny aftermarket stuff on it is the procomp light bar, stubby stock front bumper and trailer hitch. I've only had it off road once at the Texas sized Jeep meet and that's it. I'd rather not get taken for a ride with these guys again. I've looked around and can't find anything loose. But it sounds like a couple of washers loose on a bolt. Any ideas?????
I'm currently experiencing a clunk too. The clunk sound similar as if you grab the tie rod and move it up and down. the clunk will happen between 15 and 45 MPH when going over a bumps on the road. I I am not sure whatt is causing it, but I searched a lot of forums and try a lot of things to no avail. The next step is to replace tie rod, and the drag link.
07 Unl Rubi stcock 13000 miles AUT
found the culpret!! The shock is blown, and the stealership will be covering it under warrenty. one problem...... it's on a national back order and is could be anywhere from 3days to 3months to the shock in.......... so yeah to fix the problem they switched the driver and passenger side shocks and the problem went away. Looks like I'll be taking it easy for a while untill the shock gets it.
Superlift shocks for stock JK at $32 each: http://www.quadratec.com/products/16200_010.htm
My regards,
Widewing
are the back shocks the same as the front????? Not a bad deal and when I upgrade to a 2" lift, I'd already have the shocks inplace. Thanks for the tip
