Rain and leaks
Rain and leaks
So today after work noticed leaks coming from both drivers side and passengers side on my soft top. Steady rain today and leakage is minimal limited to on the doors. Instinct is no fret I'm not sitting in water and I kinda expected this as the soft top has a lot of opportunity for water travel. So my question is, am I all good or do I worry about any internal rust... ie door internals, remind you leaking is minimal. First leaks noticed every thing seem sealed as usual just believe it has been the amount of wind and rain
I started to notice my softtop leaking this past summer. I drips at the passenger B pillar. I have removed the carpet bc it smells whem it is wet but I am not worried about rust on the floor, it dries out fast. I havent thought about anythinf in the doora rusting..any one have any experience?
Mine was leaking on passenger side a lot-say an inch or two on the floorboard when it rained. Dealer fixed it with an oversized door seal. No problems since. BTW mines a softtop also. As far as rust goes that would depend how well you clean it after offroading. My TJ leaked also after 3 or 4 years, but never had trouble with rust. Just took carpets out a couple times each summer and hosed it out real good.
Haven't removed or even looked under the carpet. Is the paint covering the floor boards totally? I have seen where the roll bars are not totally painted. Does primer protect from rust. A few years ago I had an xj rust on the driver side door hinge and fall off local shops said that was typical. Switching to hard top soon any areas to monitor as I feel leaks are limited to the hard top only... For now
I brought my jk11 in for the soft top recall the other week, I noticed on the work order that the dealer also performed another recall regarding weather stripping for leaks.
Yeah checked that they are in. Seems like it's getting in through gaps in the weather stripping seems to gap a bunch when the door is shut. I am going to re check the header fit when the rain let's up.
