Question on rear brakes
I noticed when I rotated my tires last weekend that the rear wheels have significantly more brake dust than the front wheels, I also notice this when I wash my Jeep.
In all of my years with cars and trucks, my experience is that the front wheels are the ones that get the most brake dust, even my Expedition with 4 wheel disk brakes got it worse in the front.
Could there be something wrong with my rear brakes? maybe the emergency brake is still partly engaged? (the lever is all the way down) how else can I check this?
P.S. Your E-brake doesn't use the disk pads.
The E-brake is inside the disc assembly, you need to remove the disc to inspect it. If you have been in the mud or water they may need to be cleaned up, possibly stuck that would make dust if they are rubbing.
So I need to remove the caliper and the disk? Any one know if there is a writeup on doing that? I imagine if there is rubbing, that it would affect my MPG's as well.
Only depending on how stuck they are. Easy way to check, lift up the back end of the jeep, and see if the wheel turns harder on one side than the other. I'm only talking about the first couple inches of movement before the driveline starts turning. If one of the E brakes is stuck on, the wheel will be hard to turn and won't have that slop in it, if you know what I', referring too. Hopefully you do.
