Question on front differentail fluid change.
Old 05-17-2010, 05:51 PM
Blackmetal's Avatar
Default Question on front differentail fluid change.
I just changed the fluid of my front differential and it took almost quart to fill up. Is this normal? I mean I did not even use the whole bottle, there was some left. Anyway the way I did it was as I was filling it it started to ooze out a little and thats when you are suppose to stop right?
Any info would be great cuz tomorrow I start school and I dont what to damage anything.
Oh and why does the old oil smell really awful? It smells like diarrhea!
Old 05-17-2010, 07:19 PM
plac's Avatar
front ~ 1 quart
rear ~ 2.0 quart
updated after checking my thread..
Old 05-18-2010, 02:04 AM
Mark Doiron's Avatar
Originally Posted by plac
front ~ 1 quart
rear ~ 1.5 quart
Are you sure about that rear (D44 I assume)?
Old 05-18-2010, 04:43 AM
plac's Avatar
no, im not sure. i just guessed. its probably more like 2 qt for the D44.
but you can check my thread to confirm if i was close.
https://www.jk-forum.com/forums/show...on-2007-Sahara
Old 05-18-2010, 04:55 AM
ronjenx's Avatar
Here are the factory differential capacities for the JK:
FRONT AXLE ± .03 L (1 oz.)
186 FBI (Model 30) 1.0 L (1.05 qts)
216 FBI (Model 44) 1.3 L (1.35 qts)
REAR AXLE ± .03 L (1 oz.)
198 RBI (Model 35) 1.83 L (1.9 qts)
226 RBI (Model 44) 2.25 L (2.4 qts)
Actual amounts from factory on my vehicle:
Front Dana 44: 44oz (15oz above bottom of fill hole) (1.4 qts)
Rear Dana 44: 72oz (slightly above bottom of fill hole) (2.25 qts)
Old 05-18-2010, 08:05 AM
*Seth*'s Avatar
Why does the rear D44 hold more oil than the front D44?
Old 05-18-2010, 08:06 AM
plac's Avatar
i wondered that, but didnt feel like asking..
Old 05-18-2010, 08:40 AM
joe002's Avatar
Because in the front you are only filling the center section, while in the rear to oil goes down the tubes too.
Old 05-18-2010, 08:48 AM
ronjenx's Avatar
Yes, to lube the axle bearings.
Old 05-22-2010, 07:52 PM
taher2.1's Avatar
Changed the oil myself for the first time..Rear took 2 qts to fill. Is that Normal of I should put more..
Quick Reply: Question on front differentail fluid change.
