Pulled a fuse out while jeep was running and now wont start
Originally Posted by pirate
Do you know anybody with a jeep that you can borrow the relay from? Did you try r and r the relay? Did you check to make sure all the sockets/terminals are good? As well have you checked the fuel pump relay?
I think your gonna need to find someone with a obd2 reader and clear what ever codes are in memory. Have you tried to see if your getting pressure at the fuel rail?
Originally Posted by Blade
Sounds like you might have shorted your TIPM(Totally Integrated Power Module). That is the only thing I can think of that would cause your problem, as it is the only thing that controls your fuel, spark, and starter.
Have you tried starting it in 4lo? I know in man it will start in lo without the clutch, it could be the same with an auto?
You have to make a trip to the dealer. Sorry to be the one to have to point you in that direction.
Hopefully once you get there it won't be too painful.
I've run out of quick checks to do, and every thing else is gonna cost money and maybe not fix it. The dealer sounds like its gonna be the best bet now. Let us know what the issue is when you find out!
thanks again
Dosen't turning the key off an on 3x quickly show the codes on the odometer? Leave it on on the last turn (on as in power not start). You won't be able to clear codes but you will know what they are.
Thanks
Found out a while ago about what was causing my jeep to not start it was In a security lock out mode the computer thought someone was trying to steel it so it locked me out just needed to be rebooted and it run great for a few months till I hit a mud hole too fast and hydro locked the motor and now I'm
Looking for a new motor if anyone knows anyone that has one kicking around that would be sweet.
