Power locks on factory half doors, need owners help on this...
Hey guys!
I have a 09 Rubicon Unlimited and just purchased the parts from Jeepsareus needed to build my own set of four half doors. My issue is I have power locks on my full doors and the door skins for the half do not have the switches there.
So you lucky guys out there that have the factory power half doors can you tell me or show pictures of where the switch is for locking and unlocking your doors are? Many thanks!
Hey guys!
factory power half doors, where is the unlock switch!
Yes I did order it with the power lock option, the front wiring harness has two plugsand the rear has one that are for the power window motor and the power window switch. Obviously the plug for the power lock is being used. I just thought maybe the power half doors might have the unlock door switch on the door. Can anyone answer that? On the power half doors where is the unlock switch located, on the doors or on the dash? Once I figure that all out, I'll call the retailer and have it sorted out!
Hey guys!
They work GREAT! If someone tries to Unlock the doors from the outside, by reaching inside of your Jeep and flipping the Paddle Lock, the Alarm will go off when the Door is Opened.
Best of Luck!
Cheers!
BB
So, if I got it all hooked up then the doors should lock and unlock via the remote and lock when you start driving. Mine so far all the do is when I open the doors, the interior light goes on with the exception of the rear right door. So, any suggestions on how to trouble shoot this situation? As mentioned before the wiring looks like it is for the full doors as they have the plugs for the glass motors and in the front has the plugs for the power lock switches... Any help is appreciated as it is the season for enjoying the weather!
