Power Door Lock
Power Door Lock
Just bought a used 2007 Sahara with power windows and locks. The door lock switches are working. Both switches will unlock the drivers side door. The switches will not unlock the passenger door every time. Only about every 4th time. I'm sure someone has had the same issue at some point. Is the locking mechanism vacuum driven? Any ideas on a fix?
If you rule out poor connection then I would think you have a bad power door lock acuator.
These are 12 volt electrically powered door locks...no vacuum. The power door lock actuator is built into the latch.
Replacement would be:
04589276AE (RIGHT)
04589277AE (LEFT)
04589276AE (RIGHT)
04589277AE (LEFT)
Former Member
Like he said follow the wires that go from the door to the disconnect plug just past the door strap. You might even find that there is evidence of a water leak from above that area under the hood at the top of the fire wall. There's a soft filler patch up there that tends to lose it's caulked seal. Might kill two birds with one stone here. good time to put di-electric grease in all the door disconnects to prevent corrosion as well.
