possible problems with some 3.6 pentastar engines
Old 08-17-2012 | 10:33 PM
  #841
ccuchris's Avatar
Originally Posted by JamesWyatt
The only person here making things personal is you. All you seem to want to do is complain. And you're just acting like a fussy little baby because you've not being properly validated and high-fived.
You keep constipating this thread by saying the same thing over and over. Can you wait to post again until you have some new information to share or a new idea or point to make?
well I believe that is the kettle calling the pot black..
Old 08-17-2012 | 10:37 PM
  #842
MGM2's Avatar
Originally Posted by ccuchris
So if this is indeed a known issue and I believe it is and from their own admissions in the media it is ,wouldnt this be three attempts at fixing the same problem? And if they tried worming there way out of it or claiming it was not three attempts at fixing the same problem wouldn't that constitute fraud?
It seems that way then you have a case, If you have had three attempts than you should no problem getting them to buy it back.
Old 08-17-2012 | 10:58 PM
  #843
Gort's Avatar
Originally Posted by RoysRig
Pick Your Oil Change
Good
Regular Oil Change
$19.95
Better
Synthetic Oil Change
$49.95
Best
Synthetic Oil
$68.95
Can someone tell me the difference between the Better and Best?
Just speculation, mind you, but the difference between "better" and "best" may have something to do with Mobil 1's own marketing. If you go to Mobil's site and run through the "What's the right oil for my car?" checklist, they do actually distinguish between the regular Mobil 1 synthetic ("superior" protection) and the Mobil 1 Extended Performance ("ultimate" protection)?
Or maybe they just are shameless about their desire to separate the automotively-challenged people from their money?
Or maybe the service department is just stupid?
Old 08-17-2012 | 11:51 PM
  #844
MeatCurtains's Avatar
If you are so world class butthurt about this get a lawyer and make them buy it back. Go buy your RAV4 and be done with it.
I understand you may be pissed, just remember you are not the only one in your situation.
You are getting so petty about this I would be willing to guess you are one of the ones who wouldn't have been happy if they threw a whole brand new motor in it. Seriously man, sell it or get over it.
Old 08-18-2012 | 03:31 AM
  #845
33 williys 77's Avatar
Originally Posted by 33 williys 77
If Chrysler is cooling the head first then it is a design flaw with the old heads and if these heads have ( what we use to call steam ports ) then maybe the NEW heads have larger steam ports for more coolant flow.
Just a guess or conjecture on my part
33
I guess I should have said more controled coolant flow.
Old 08-18-2012 | 06:21 AM
  #846
Sunkist Rubi's Avatar
You asked so I will answer, Mazda Rotory. Fun little engine, but what a piece of crap! Burns a quart of oil every 3k miles for the first 20K miles. and by the time you hit 50K. You add as much oil as gas.
I contemplated a RX7, 8 more than once. Yes the Rotary engines are a little troublesome. From what I've read the rotor vanes that seal off the combustion chamber as it rotates around are the main problem. Have you ever viewed how this engine works? It is an excellent overall design, low moving part count, fairly simple, just that one part, probably the most important, isn't the best.
My original question was asked about the Pentastar, if anybody knows of one that has attained 100k miles or more?
Old 08-18-2012 | 06:27 AM
  #847
jkrubcon's Avatar
Speculating, I'm sure there's some vans out there over 100k.
Old 08-18-2012 | 06:32 AM
  #848
jkrubcon's Avatar
Edit------I think vans have a different head design.
Old 08-18-2012 | 07:51 AM
  #849
lanslide's Avatar
So...I changed my 12JK's oil today with Mobil 1 at 2,000 miles (2nd oil change). I listened intently to the engine afterwards and it sounds smooth but kinda like a sewing machine. Is this the ticking sound? It isn't loud and sounds smooth from all around the engine.
Is the sound a tick, tap, or knock? I would never have given it a second thought if I hadn't read this thread. I thought this was a normal sound for an engine. My 1993 YJ's engine sounded like a sewing machine too.
Old 08-18-2012 | 08:11 AM
  #850
RoysRig's Avatar
No, you will know it when you hear it. It's very distinct.
Quick Reply: possible problems with some 3.6 pentastar engines
