possible problems with some 3.6 pentastar engines
Old 05-08-2012 | 10:14 PM
  #111
Cool Danish's Avatar
Originally Posted by nakednuns
I forgot to post what the tech said about my head replacement. Here is what he said......
"Customer states vehicle makes loud ticking noise : check and advise
Verified customer concern and found tick on drivers side. Isolated noise under valve cover and contacted Star center and was advised to remove valve cover and inspect lifters.
Removed intake, valve cover and camshafts. Found spongy lifter and others were LOOSE in the bore.
Measured bore and submitted data to Chysler and was advised to replace head and lifter.
Opted to replace ALL lifters in case of unidentified failure.
Replaced head, lifters and re-installed all removed components.
Test drove and no tick was heard. Vehicle drove good"
I like the fact the mechanic opted to replace ALL the lifters and not just one!
Hopefully this little bit of information will help others if and when they have theirs worked on for reference.
All is still well with mine except a slight oil burning smell I can't find. Have degreased and degreased till I am blue in the face. Everything is dry but can't figure out where the burning oil smell is coming from, nor can the dealership.
Someone else on the Forum said that they had the same problem with burn oil smell. It turned out to be from when the dealer did an oil change and they got oil on the foam that is glued to the underside of the plastic engine cover (with the JEEP logo on it). I think he washed it out really good with detergent and it removed the smell.
Something to look into.
Old 05-09-2012 | 09:11 AM
  #112
Sunkist Rubi's Avatar
New driver's side head ordered; now I wait.
Old 05-09-2012 | 01:27 PM
  #113
Sprocket's Avatar
My 2012 ticker update:
Days in shop = 3
Was told yesterday they were replacing all 12 tappets.. havent heard anything since.
Old 05-09-2012 | 02:41 PM
  #114
LMT Rubi's Avatar
thank you so much for the info. I too am in the same ticking boat. However I was wondering if you could post a PDF version of the work order as a way for "others" with the same problem, to easly download and present to our service managers as proof of what is happeing to our Jeeps. Thank you in advance....
Old 05-09-2012 | 04:12 PM
  #115
vulcan classic's Avatar
Was contacted by Jeep Customer Care today regarding the ticking issue on my 2012; still waiting to here back from dealer, they wanted a few days to investigate; JCC said they will contact dealer tomorrow and get back to me, haven't had it back to shop yet 'til I hear more...
Old 05-10-2012 | 02:27 AM
  #116
I was told by my dealer a head replacement includes a new assembly which everything is new except your cams are reused. This includes all valves, valve springs, valve guides, valve seals, cam followers, rocker arms, and lifters. Which means your mechanic didn't go out of his way.
Old 05-10-2012 | 09:54 AM
  #117
Update:
Dealer called today asked to have my Jeep on Monday; gonna pull valve cover and inspect top end...here we go :(
Old 05-10-2012 | 10:40 AM
  #118
War Machine's Avatar
Thanks for the reply.
Old 05-10-2012 | 12:19 PM
  #119
stonewhite's Avatar
Just out of curiousity...how loud is the ticking? I hear a very small amount when I'm at the bank drive up window. Sounds more like exhaust ticking. I have a 2012 Rubicon built November 21, 2011. Would like to know what to listen for....
Old 05-10-2012 | 01:18 PM
  #120
Sprocket's Avatar
YouTube has vids of it.
Quick Reply: possible problems with some 3.6 pentastar engines
