Play in front wheel hubs?
Should there be any play in the front wheel hub/bearings? I have a vibration in the front end and in the steering wheel between 50-60mph. I started to put my spare tire on the front left to see if it was a tire balance issue. I jacked it up off the ground and grabbed the front wheels at the 12 o'clock and 6 o'clock position and noticed that I could feel a little play in the bearings. Not much at all (less than 1/16"). Both sides have about the same amount of play.
Is this normal?? The bearings are quiet and roll smooth.
There should be no play in the front hub bearings. They are preloaded when manufactured. The tragic thing is, they can not be adjusted.
Go to this thread to see how they are made, if you haven't already seen it:
https://www.jk-forum.com/forums/show...-Bearing-Study
Thanks for the reply. That's what i thought, too. Do you think that just a slight amount of play would cause a vibration in the front end and cause the steering wheel to shimmy a little?
A small amount of play indicates the hub is on its way out. Probably no reason to replace immediately if your symptoms aren't too bad yet. Start looking for a new hub. I have found the Timken Hub, (Timken in name only), has a lifetime warranty, and was less than $100, a year ago. I found them at VIP Auto Parts, which is a New England store.
I can see and feel the movement on the back side (inside) the hub when I wiggle it. Plus I don't think its the ball joints since the steering nuckle doesn't move when I wiggle the rotor (I have wheel spacers).
