Persistent Oil Pressure Issue - 3.8L
Not totally familiar with the 3.8L oiling system, is the oil pressure regulator part of the oil pump you replaced? A stuck regulator will dump a lot of oil straight back to the pan. Your pressure is really low hot, what is it cold? I'd be pulling the pan, pressurizing the oil galleys with a priming pot and looking for the excessive leak. What did your rod bearings and journals look like? did you Plastigauge them? Have you ever run it out of oil? The mains are first to get oil, its possible you nicked one although you did not see any metal. Back feeding the oil system and looking for the biggest leak should tell the tale.
Good luck, it can be a bit messy.
Messy indeed, in such cases I go to the service. I usually work with Westminster Motors, so just in case anyone will find this thread while looking for a solution.
