Penstar recall
Old 08-22-2012 | 11:13 AM
  #21
Wendy.Jeepchick's Avatar
Another forum member, Gort, is trying to gather the info about the build dates of the engines. He contacted me about including the info on my spreadsheet. I think it's a good idea, but most people haven't looked into that (including me).
Old 08-22-2012 | 11:15 AM
  #22
JKR's Avatar
JKR
Originally Posted by Breaktrack
Well, last week I had the "Check Engine" light come on, and when they hooked it up to read what code it was throwing, it was "Cylinder 2 Mis-fire". They cleared it and I drove most of that day before it returned. Took it back in today and they did a "Software Update" based on a TSB they'd received, and cleared it again. Hadn't driven 50 miles before the check engine light came on again.
So, I figure that, along with the ticking noise, means I'll be up for this as well.
Mac
Wow I don't know about your dealership but mine it is a few hours for even the simplest task. To go up there 3 times and them just blow you off and clear a code. If a code keeps coming up then its no mistake.
Old 08-22-2012 | 11:17 AM
  #23
SabFanInked84's Avatar
That's a valiant effort, but it could all be in vain if Chrysler decided to change the heads on the "waiting" engines. In that case, July built jeeps with engines that might have been waiting since May, might be fitted with May engines that had a chance to be fixed at that time since these engines were just sitting on the sidelines.
I guess that's some important information Chrysler left out.
Old 08-22-2012 | 11:18 AM
  #24
Mac
Breaktrack...
With the combination of the tick and the light, they should be replacing your head now. Make sure they use the rebuilt heads; the part number ends in "AB". The original heads are part "AA".
Old 08-22-2012 | 11:22 AM
  #25
Chilla's Avatar
Where is this part number located? I want to check my April built JKU.
Old 08-22-2012 | 11:25 AM
  #26
It seems you can't really find the part number easily. You can only find the Engine build date somewhere on the engine.
As for the part itself, most people realized there was a difference with the serial number once they looked at the work order when their head was replaced.
Unless someone has found out a way to find it...?
Old 08-22-2012 | 11:37 AM
  #27
I was told that the original head was only marked by a tag which was removed prior to the engine assembly in the factory. Anyone who's JK was built prior to July should just assume that they (and I) have the "AA" head. All dealerships should now have the new "AB" head. But, definitely check before the new head is installed. The dealership has to have a part number before they install a part, because it is on the invoice when they print it out.
I have been contacted by two JK owners have had the original head replaced with the old "AA" head. Both engines had to be replaced afterwards.
Old 08-22-2012 | 12:00 PM
  #28
wharris_jr's Avatar
Default Recall
I had something like this happen on a Ford truck - man I hope my engine is not one of those needing repair. Makes me sick to even think about it. I bought two 2012's at the same time.
Old 08-22-2012 | 12:43 PM
  #29
Schaumburger66's Avatar
The dealer (third one) finally agreed there is an issue. They contacted Chrysler and they are tearing apart the head for possible replacement. Chrysler is also picking up the tab for a rental ($35/day), so if you have the issue, ask about it.
Old 08-22-2012 | 12:57 PM
  #30
Gort's Avatar
Thanks for the plug.
Here's the link to the thread.
https://www.jk-forum.com/forums/stoc...d-date-244888/
The more information that I can get, the better the results will be. I think that, at the very least (assuming I get a decent sample size) it would either confirm or deny the likelihood of the issue being a manufacturing defect.
Quick Reply: Penstar recall
