parking on inclines
Old 04-07-2008 | 07:27 AM
ripsnort33's Avatar
Default parking on inclines
does it hurt the tranny in automatics when you shift from park to reverse on an incline. i always pull the e-brake before putting it in park on inclines but it still rolls back a little and has that nasty clunk when when i shift to reverse to back up. just wondering how detrimental this is to the tranny. i know squat about auto trannies so any mechanical knowledge is appreciated.
Old 04-07-2008 | 07:32 AM
Asta4125's Avatar
I know what you mean. Its not good for the car to resting all of its weight on the trans. Make it a good idea to pull the ebrake before you take your foot off the brake, once in park. This way the jeep wont rock backwards and rest on the trans. Not a trans expert, but I know it cant be good.
Old 04-07-2008 | 07:42 AM
ripsnort33's Avatar
i do but it still rolls back. it would be great if they made a line lock so that your brakes would hold as if you were holding the brake with your foot.
Old 04-07-2008 | 09:56 AM
cadmanaz's Avatar
Actually, it's better to do the following for auto tranny:
1. Pull up to your parking spot,
2. Pull the parking brake,
3. Place the gearshift in "Neutral",
4. Lift your foot off the brake pedal and let the Jeep's weight rest on the e-brake,
5. Then shift the gear into "Park".
A few times doing this and it will become habit. When you get back in your vehicle it will not be rough/hard shifting into Drive or Reverse.
Andrew
Old 04-07-2008 | 09:58 AM
cadmanaz's Avatar
Andrew
Forgot to add that the Jeep will still travel if you apply the e-brake before lifting your foot from the brake pedal, depending on the direction of the slope and what gear you were in before applying the e-brake (Drive or Reverse).
Andrew
Old 04-07-2008 | 10:56 AM
Asta4125's Avatar
Andrew
Same thing......basically you dont want the weight of your vehicle resting on your trans, and the ebrake needs to be strong enought to hold the jeeps weight, and not alowing it to rock backwards and rest on the trans.
Old 04-07-2008 | 10:59 AM
Dayton's Avatar
Andrew
Yup. What he said!
Old 04-07-2008 | 11:13 AM
RedneckJeep's Avatar
If you saw the park sprag, you'd wonder how in the hell it ever held the Jeep in place. Naw, it won't hurt it, but it does help to engage the parking brake first.
Old 04-07-2008 | 11:59 AM
ripsnort33's Avatar
very cool! thanks for all the input.
Old 04-07-2008 | 12:12 PM
JKJeremy's Avatar
not trying to start anything but i always thought an 'e-brake' was what the import street racer crowd used for drifting (sarcasm) my guess is that would be pretty hard to do in a JK unless maybe you were muddin'
i believe the term you were referring to is the emergency brake or the hand brake.
to each his own....
Quick Reply: parking on inclines
