Parking break issue
Originally Posted by murdoc319
i had the ratchet go last fall, but when i park it on an incline the jeep moves a touch and i hear a loud metallic click that i reallly dont like.. i hate the whole E-brake in general
I was just browsing some Jeep forums and came across a thread that was titled "Self calibrating your Jeep E-Brake". I do not have the link but the theory behind the thread was this...throw it in drive or 1st gear and go forward and pull the e-brake until the vehicle stops, then put it in reverse and go backward and pull the e-brake again until the vehicles stops. Repeat 2 or 3 times and your e-brake will have re-adjusted itself. Mind you, this is not a permanent fix for faulty parts but it did increase the tension on mine enough to make it worth using. I guess what happens is when we pull the e-brake, the spring weakens and 1 of the cables gets pulled further than the other. Doing this little Jeep dance with the e-brake pulls the cables so the tension on both is closer to being equal to one another. If you try it and it doesn't work...sorry, but it did help mine so hopefully you can have similar results. Good luck!
This drill to tighten up the EB is exactly how you could tighten up drum brakes having self-adjusters: Back up and hit the pedal repeatedly. Only difference is you pull the EB handle instead of hitting the brake pedal. Hydraulic disc brakes are inherently self-adjusting, but the EB cable is not so there is an adjuster. Sounds like the EB adjuster wheel may have an auto-adjuster like the old drum brakes.
Great trick if it works! Much easier than climbing under with the tool.
I've read about the EB handle and linkage falling apart. Some think it happens because of yanking hard on an EB that won't hold. If it is this easy to keep the EB adjusted, it might help with the linkage failure problem.
There is no self-adjusting mechanism in the Jeep JK e-brake. When you do the accelerate and brake nonsense, you are just equalizing the two cables. That may provide some relief from one side or the other being weak. But the JK Jeep design is terrible. I found it virtually impossible to adjust the e-brake star wheel without removing the drum. And even then, with new pads literally dragging against the drum, the e-brake still doesn't hold the Jeep very well. It just a sucky design--Chrysler should be embarassed. It's an EMERGENCY brake for crying out loud!
Warranty??
Just pulled the e handle this morning and "snap"... now e brake handle is inoperative. Think cable or whatever is attached to handle has snapped. What is the warranty on this component? 2008 with 45k KMS
It should be part of the basic, vehicle warranty. Here in the U.S. that would be three years/36K miles. Not certain what the warranty would be up in Canada, though. Didn't they give you a copy of the warranty? If not, you can probably find it at Jeep.com (Jeep.ca?).
1 Post
my 2008 4dr went 3 times as well. replaced by dealer all three times. holds for a few months then goes, about to go again actually. i'm getting pretty sick of this since i park on a slight incline everyday
This is so funny my 2011 3300 miles I was messing around in my warehouse when I parked this morning and now it has a grudging noise in the handle when I apply my p brake
