p0305 misfire
p0305 misfire
im getting code p0305 which is cylinder 3 misfire.
the question id like to ask is.
is there a way (using a multimeter or other method) to test which component is causing a misfire. before i go slapping parts on it in hope
my guess is it can be any of the following
spark plug
plug wire
electronic distributer
fuel injector
injector harness
i think cylinder 3 is the passenger side in the far back. so the less reaching back there i have to do the better
spark plug
plug wire
fuel injector
injector harness
spark plug
plug wire
fuel injector
injector harness
spark plug
plug wire
fuel injector
injector harness
#5 cylinder is the rear cylinder on the right bank, (passenger side on LHD vehicles).
Lots of things can cause a misfire. "Engine Mechanical" in the list below is a big subject.
Some of the other tests require the dealer computer to activate certain circuits.
[h=2]P0305-CYLINDER 5 MISFIRE[/h]
- When Monitored: Any time the engine is running, and the adaptive numerator has been successfully updated.
- Set Condition: The threshold to set the fault is application specific; it is tied to the level of misfire that will cause emissions to increase to 1.5 times the standard or in some cases 1%. It is always a two trip fault above the calibrated RPM. It takes 1 soft fail to set a malfunction and two trips to set the MIL. Three good trips to turn off the MIL.
[TABLE]
[TR]
[TD="bgcolor: white"]Possible Causes
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]ASD RELAY OUTPUT CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]INJECTOR 5 CONTROL CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]COIL CONTROL 2 CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]IGNITION WIRE
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]SPARK PLUG
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]IGNITION COIL
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]FUEL PUMP INLET STRAINER PLUGGED
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]RESTRICTED FUEL SUPPLY LINE
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]FUEL PUMP MODULE
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]FUEL PRESSURE LEAK DOWN
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]FUEL INJECTOR
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]ENGINE MECHANICAL
[/TD]
[/TR]
[TR]
[TD="bgcolor: white"]POWERTRAIN CONTROL MODULE (PCM)
[/TD]
[/TR]
[/TABLE]
code p0305
lucky for you but my just turned on. So, I'm guessing that this is something I have to take in or can I try the good old college try and fix it myself.
I saw in your profile you have 2007... if you have never changed your spark plugs, it probably wouldn't be a bad idea to go ahead and change them even if it doesn't fix your problem.
