Ordered New JK last week
I find the best thing about this forum is that if you do have a problem with your JK, then you can post a question or search previous posts on the same topic to get an idea of the causes and solution of your Jeep's issues before you go back to the dealer . Most of the guys & gals on here are real helpful & will often even go out to their Jeep there & then & take a photo or check a spec of something & then come straight back in & post the results.
If you just turn up to the dealer & say "theres a squealing sound coming from somewhere under the hood" or "my clutch doesn't feel right" you'll most likely get the old "could not duplicate problem" response from the service guys. But if you say "My clutch problem appears to be a throwout bearing issue; here are the symptoms..., and here are the relevant TSB numbers concerned with this common fault...and from what I've heard the most common way to rectify this fault is to..." then you're more than likely to have the problem dealt with under warrany fist try as the dealers think you know what you're talking about and won't waste their time trying to BS you; that's been my experience anyway.
Had my JK 18 months now & still check this forum at least weekly for updates, as it's been invaluable to me in the past.
Congratulations! I ordered my 1st wrangler a white Rubicon with 6-speed manual trans on April 5. I've been passing by the dealership every week just to check the status on the car and look at other JK's on the lot. Friday night dealership called and reported that the car just got in and will be ready for pick up early next week after additional Mopar parts installed (heated seats, hood locks, gas filler door). Scheduled pick up for Tuesday afternoon after work. Now I'm hooked to this forum for possible future mods. Rubi will be used for work as DD about 50 miles per day. Suggestions are welcome.
second day!
second dayy, if it was only a lil warmer i woulda taken the doors off too....
and to you guyss i know i called the stealership everydayyy till it came. and when it did it took a few days to get ready.. and i went and visited it after the dealership had closedd but dontt worry jeep brothersss waitt it outt and the day it comess hope the sunns a shinennn
