oil filter change mess
I like working on my 2011 JK but I'm one of those guys who wrenches on their back, on the floor, in the garage. I also like a neat job so one of the tasks I dread is changing the oil filter. I ALWAYS drip oil onto the axle and floor. Is there a trick to getting the filter off without dripping onto the engine and axle? Is the a filter relocation kit?
You can use aluminum foil shaped into a trough to channel the oil away to where you want it.
I don't use it on the Jeep, but it's good on my bike as the filter is directly above the headers.
5-inch Tupperware container (don't tell my wife). Small container fits perfectly on top of the axle tube right below the filter, then I just loosen the filter and everything drops right into the container.
Or use Mobile 1 oil filters. Their anti-drainback valves are so bad that if you let the Jeep sit for more than an hour, all oil will drain out of the filter and into the pan, so there's nothing in there to drip when you remove the filter.
