Oil change through the dipstick
Old 12-11-2010 | 02:25 PM
sheepdog's Avatar
Default Oil change through the dipstick
Can you drain the engine oil from your JK through the dipstick location with an oil extractor?
I know that some engines have to be done this way. It's a lot less likely to drop oil in the driveway.
Old 12-11-2010 | 03:26 PM
Mike Davis's Avatar
I bought an oil extractor to do my wifes Toyo so I wouldn't need to get it up on ramps. It came with 2 sizes of plastic hoses. Neither one will work in the JK. There must be some weird sharp turn before the dip stick tube enters the oil pan. Let me know if you are successful.
Old 12-11-2010 | 03:49 PM
ChrisLe's Avatar
Its commonly done on boat engines. Assuming there's nothing to block the tube from getting down to the bottom of the oil pan (baffles, windage tray, etc.), it can probably be done.
Old 12-11-2010 | 03:55 PM
sheepdog's Avatar
I was looking at this one
Old 12-11-2010 | 04:01 PM
h1ker's Avatar
Just drain it
Old 12-11-2010 | 04:04 PM
Cpt. Flapjack's Avatar
You are much better off draining thru the drain in the pan. This allows any sediment to run out thru the drain hole and you can clean off the magnet on the drain plug and make sure there is no excessive wear.
Old 12-11-2010 | 04:06 PM
Tgoods 09 X's Avatar
If you are worried about spillage just lay down some cardboard and oil dry. Or find a shop in your area that charges $15 for a change..
Old 12-11-2010 | 04:36 PM
Pluke the 2's Avatar
Originally Posted by ECHO
YOUR NOT THINKING WITH YOUR DIPSTICK JIMMIE
LOL. that is funny.
Old 12-11-2010 | 05:28 PM
ronjenx's Avatar
I use an oil extractor through the dip stick tube.
The first time I used it, I pulled the drain plug after to see if it got all the oil.
Not a single additional drop cam out.
I'm not worried about sediment because I do it right after shutting the engine off, after a trip. Any particals are still in suspension. Hot oil is much easier to extract.
Every once in a while I'll pull the plug and drain, just to cover all bases.
I prefer to use the oil extractor.
The one I have is the 6.5 liter version (the tall one) made by Pella.
I don't know how much they are now, but a few years ago I bought mine for around $35.
Old 12-11-2010 | 06:14 PM
Max172's Avatar
Does anyone know how to make an easy job more difficult?
Just wondering.
Quick Reply: Oil change through the dipstick
