Oil change at every 3k or 5k?
#52
Since you're getting the warning at 2500, you seem to be one of the folks who's driving style (duty cycle) actually does warrant a 3k change interval.
#53
Most of the oil is in the pan, if you let the engine cool off a little , but still warm enough to drain the oil properly.
I have changed the oil filter without changing the oil, some oil will spill out of the filter and the filter port, but very little. I found this out when I was expiermenting with different oil filters due to dry start issues regarding bad anti drain valves. Now I use the Napa Gold Filter # 1348, excellant filter.
Just wanted to chime in and say it is def possible to change the filter without draining the oil.
SLIM
SLIM
