Odd issue (SOLVED)
Odd issue (SOLVED)
Has anyone seen this problem, I am suspecting something in the master cylinder. When taking off the clutch feels great (I installed a new clutch and TB a few months ago) but after getting up to a certain speed like 3rd gear the clutch becomes harder to push. I have sucked out the reservoir and refilled twice to make sure its not a break down in the fluid and this has improved it some. No noise, no chatter, nothing but that real stiff feeling on the clutch, but like I said only when past 2nd gear. The clutch and TB are good. 2007 JKU BTW
I checked again and there is absolutely no noise and no grinding feeling in the pedal like a throw out bearing. It's just like it gets stiffer after 2nd gear. I even had the wife drive it to make sure I wasn't being paranoid and she noticed it as well
Yes I've always done my own work and clutches are actually easy for me except dropping the damn tranny out (getting too old for this shit ), the last clutch I did was in my TJ and I actually rebuilt the transmission while I was at it. The clutch has been acting fine actually perfect since I've done it just until a few days ago. It's actually still working great besides the fact the clutch pedal is hard to push, but there doesn't seem to be any binding past the slave cylinder so I have to assume it's one of those two, but I've never seen a master cylinder act this way unless the spring broke inside or something
HostileJK (08-01-2018)
Maybe the best bet would just to replace them both, she does have 155,000 on her. Then again I wont know what actually fixed it and that might drive me crazy.
Odd issue hard to push clutch (Solved)
Okay okay I'm a little embarrassed to admit this one but even seasony mechanical dude or ladies can screw up once in awhile.
When I reinstalled the tranny I remember lubricating both pivots and putting anti seize on the shaft so it would slide nice, however the thing I don't remember doing is popping the ball off the end of the slave shaft and lubricating that pivot.
So I went home, jacked her up and pulled the slave cylinder out and lo and behold I popped it off and it was dry as a popcorn fart. I put some nice red high temp grease and popped the ball back on, put it back together and low and behold she drives like a dream again and as smooth as a baby's ass.
So in ending, as much as I hate to admit an embarrassing moment like this if it helps somebody learn or solve their own problem like mine, then hey I'm all for it
I updated my original post by putting solved behind it, but that parts not showing up so hopefully somebody else finds this helpful through search.
