No Straight Answers.....
My Jeep sits down in the front 1.75" from the rear. To me, that's a hell of a lot. I had been thinking about a BB for the Jeep, but I will still end up with a very unlevel vehicle. I have thought about taking it to the dealer and seeing how they would react to my complaint. I wonder how willing they would be to swap out the front springs for something more heavy duty? Nearly everything I have and everyone I have talked to knows nothing concrete about stock spring rates. Any thoughts?
They won't do anything... the JK is manufactured to have that rake. A few people complain about it and have added spacers to level it out...there are others who say the JK needs that rake to drive properly because that was the stock design. Some lifts level the Jeep others don't. I bought the RC BB which is 2.5" in the front and 2" in the rear. I also have a Rampage Bumper and a winch. I installed the 2.5 inch spacer in the front and without installing the rear spacer of my BB the Jeep still sat 1/4 higher in the rear... I ended up leaving the rear spacer out.
We can't get Jeep to fix the real problems ( like a leaking top ), I highly doubt you can get them to change something that is the way it is supposed to be.
I believe the "rake" is on the unlimited becuase of the towing capacity(3500lbs)
If you were to actually put a 3500lb trailer on your jeep i'm sure it would squat pretty bad so I believe the rear sits higher than the front. Not the other way around (fronts sits lower than rear) which is how most people describe it.
The rake's main design feature is that when you load it up with 5 people and some beer, it should sit level. Obviously, this does not take into account futur mods people will do but it makes perfect sence.
Very often I see people that level out their Jeeps, but when time comes to head to a trail far away, it looks like they are driving a boat!
So to each his own, but there is a method and reason behind this evil rake.
The dealer won't do anything about this. Look at the majority of Jeep vehicles, they all sit the same way. What's it called.. the Commander? It's even more noticeable. Look at trucks, they all sit that way. It's just the way vehicles are made. You just have to get some spacers to put in the front to compensate for it. It's a part of life.
Here's what it looks like:
This is silly guys. Every vehicle has a 'rake" to it, and if it was level someone would belly ache that it looked weird as soon as they put an ice chest in the back.
Do what you want with the leveling but Chrysler will not be able to please everyone.
I'm not saying your wrong... I'm asking because I don't know why it would shorten the life span.
