No Start Clutch Safety Switch
Old 12-11-2020, 03:52 AM
ryanmeetsawolf's Avatar
Default No Start Clutch Safety Switch
Does anyone know how the clutch master cylinder tells the clutch interlock switch that the clutch is pressed in to start the engine? I have ruled out the interlock sensor as the issue, and I am now thinking it's the clutch master cylinder, but I can't find anything online explaining how it functions. I have some guesses lol. Currently starting in 4low. 2012 JK Manual Transmission. Thanks!
Old 12-11-2020, 06:04 AM
Mark Doiron's Avatar
Perhaps this photo I shot when I swapped out the master cylinder will help. I can make an educated guess how it works, but it's likely pretty much what you are thinking. You press the clutch and the master cylinder provides hydraulic pressure to the slave cylinder. At the same time it also activates the interlock sensor, which is a part of the master cylinder, sending that signal to the Jeep to allow it to start. I guess where I'm confused by your question is you suspect the master cylinder, but not the interlock switch, which is part of the master cylinder.
Old 12-11-2020, 11:00 AM
Thanks, Mark! I've pulled my interlock sensor and tested it in another Jeep and it works fine, which leads me to believe whatever triggers the interlock sensor inside the cylinder is faulty. I replaced my factory cylinder 6 months ago after a seal broke and all of the brake fluid emptied on my floor board. I used a car quest part because that's what was near me. I spoke to one of their technicians this morning, and he couldn't figure out what was inside the cylinder, because he didn't have access to the diagrams, but he is putting a new cylinder in the mail on Monday. I'll swap it out and keep you posted. Also, the interlock sensor pops off of the side of the clutch master cylinder.
Mark Doiron (12-12-2020)
Old 12-11-2020, 08:08 PM
Sixty4x4's Avatar
Just to be sure why don't you unplug the connector and get a helper in the driver seat to turn the key to start when you have the two terminals shorted with a jumper of some sort. If it starts get new MC because I do not believe the switch is serviceable other than replacement of the entire unit.
Old 12-12-2020, 09:10 AM
Jay2013jk's Avatar
This mechanism participates in the electronic controls & pressurizing the line and Slave Cylinder for starting a manual trans Jeep Wrangler; this is the 2012 part list price is $35.00 68029261AA SWITCH, Clutch Starter Interlock SWITCH, Clutch Starter Interlock Usage: JEEP - 4WD [J], JEEP - 2WD [T], JEEP - 4WD (RHD) [U]; SPORT UTILITY 4-DR TYPE #4 [74]; 6-Speed Manual NSG370 Transmission [DEH]. The picture posted by Mark is the switch & there is a sliding mechanism component inside. You might find this informative:
Mark Doiron (12-14-2020)
Old 12-14-2020, 06:58 AM
This is a good video, but it doesn't help me with my JK. At this point, I wish I had a TJ. Here's a photo of the interlock sensor on a JK.
karls10jk (12-21-2020)
Old 12-21-2020, 04:14 AM
Update: The jeep is back to normal after installing a new clutch master cylinder over the weekend. I ended up picking up a LUK cylinder, after installing the Car Quest replacement, and then finding out the slave cylinder line wouldn't seat into the new cylinder. The LUK park looked and felt just as good a Mopar. Moral of the story, don't buy Car Quest parts.
Mark Doiron (12-23-2020)
Old 12-23-2020, 01:56 AM
Thanks for the closure. Always helpful to future readers.
Old 02-02-2022, 05:29 AM
rgvtlv's Avatar
Were you able to remove the sensor (in the picture) with the clutch master cylinder installed?
Old 02-05-2022, 11:56 AM
A bit dated, but here's the procedure.
https://www.jk-forum.com/forums/jk-w...cedure-311575/
Quick Reply: No Start Clutch Safety Switch
