No Highway Power
all I can tell is you have an '08 2dr 6sp
you should have 3.73 gearing
even with my heavier '07 4dr, 3.21 gearing 6sp I never encountered a problem maintaining highway speeds in 6th...until I got my 33's on
If you are running 3.21 gears I have felt your frustration. The performance of my stock was unacceptable for my taste.
IMO, the JK is obviously geared high with a strong bias towards fuel economy.
However, now even though I am running 35" tires, the 5.13 gears and the Flashpaq have changed the performance personality. I can sustain 80-85 MPH on the flat (albeit with minimum ability to accelerate at that speed). My JK will also maintain 70 MPH on all but the steepest inclines in OD.
With a 6 spd you have more flexibility, but even manual shifting has its limits.
Following this thread and this most likely is a stupid question...but I will ask anyway!
Is it hard on my jeep to run the rpm's around 3000rpm to keep up with the local traffic for a long period of time? That is 3.73's, auto, overdrive off with heavy 33" tires...
No. It can do it all day long. Like I said a few posts ago, nothing wrong with having the transmission in 1:1 if needed. That's why there is an O/D Off button.
Anyways I put a auxiliary tranny cooler on it, fluid goes through the radiator cooler, then the auxiliary cooler mounted in front of the radiator. So I can run in those gears(1st and 2nd) all day long basically
Hey thanks guys for all the posts. Right now my jeep is pretty stock except for the wheels and tires, but they are not 33's yet(juat 265/70/17's). So I guess I will just keep doing what I am doing. Like I said its mainly going into the wind.
With time I will more than likely get diff. gearing.
