New bumper = much better 5k towing
I haven't ever seen anything about it lol I would say that they are both rated artificially low, I have a 23ft bay boat that the bare hull weighs 1500lbs plus motor, fuel, and everything else in the boat, I would say it probably weighs close to 2500lbs and my 2 door pulls it perfectly fine all the time. I know that's not way over the "limit" like your 4 door pulling 5000lbs but I feel like it could easily pull around 3500lbs assuming tongue weight wasn't crazy high
I believe that the maximum tow capability has more to do with the ability to stop the trailer weight than the weight it can move forward.
It's a safety issue; do you want a 5,000 lb load "horsing" your Jeep around, or 3500 lb when you get into a panic stop?
It's why NFL teams like 350 lb linemen...
I believe that the maximum tow capability has more to do with the ability to stop the trailer weight than the weight it can move forward. It's a safety issue; do you want a 5,000 lb load "horsing" your Jeep around, or 3500 lb when you get into a panic stop? It's why NFL teams like 350 lb linemen...
I did a bunch of searching before I ordered my 2012 JKU because I knew I wanted to tow with it. I went to Chrysler websites for other countries like Germany, Switzerland, Australia, etc. most have the gas powered JKU rated higher than the 3500 allowed in the US. Two prime theories on why. One is that it is considered a convertible since the top and doors don't protect, which is also why uhaul won't rent a trailer if you have a soft top jeep. The second has to do with maintaining a certain speed up some mountain pass in Colorado. What's interesting in my case is that I have towed my toyhauler empty at 3500 pounds and full at 5000 pounds and I can't tell any difference between the two. On the highway, it is the wind resistance that matters, not as much as the max weight.
FB
Hmmm. Uhaul rented me a trailer to tow one way across the country in my 08 JK soft top. No one batted an eye. Subject didn't even come up. While the vehicle may very well pull the trailer, if you are over the weight ratings for the vehicle you very well may be civilly liable if that vehicle is involved in an accident. That accident may not even necessarily have been your fault but you may find yourself being held responsible civilly or criminally depending upon severity of the accident. FB
i have the same rear bumper on mine and i pull my 1300lb jetski around every weekend. I also noticed a difference in towing it when i put the new bumper on. seems to be a little more stable now.
FB
What the factory hitch is bolted to is the cross support between the frame rails which probably can't handle the weight over 3500 lbs that why the jk has a lower tow rate . If the bumper with hitch mount has a higher tow weight is probably the way way it mounts to the frame
