New bumper = much better 5k towing
WOW. I've been towing a heavy toyhauler for about 2 yrs. I just installed a smittybilt xrc rear bumper. My towing experience is now light years better. I think the reason is that the weight distribution hitch is now effective. The stick receiver doesn't have the torsional strength for effective use of the weight dist setup. The trip I am on now was about 350 miles in PA and VA. Te weight I am towing is close to 5000 pounds. See pics. The primary improvement is in ride handling, particularly over bumps like expansion joints in the road.
I don't know my trailers tongue weight. The smittybilt receiver is class 3 with 500 pound tongue weight and 5000 pound tow capacity. Of course they don't recommend towing more than what the jeep is rated for. I can tell you that towing this trailer with a weight distribution hitch, dual axle trailer brakes, friction sway control, is not a problem. I've done nearly 6000 miles of towing. This bumper really makes it better.
I haven't looked at the weight limits but surely it can pull more than that? I will have to look into it. I figured the 2 door was around 3500-4000 and 4 door more than that
edit: just looked and 4 door is 3500lbs. and 2 door is 2000lbs. holy crap that is nothing.
I haven't looked at the weight limits but surely it can pull more than that? I will have to look into it. I figured the 2 door was around 3500-4000 and 4 door more than that edit: just looked and 4 door is 3500lbs. and 2 door is 2000lbs. holy crap that is nothing.
I'm trying to understand how a new bumper makes for a better towing experience. Isn't the hitch mounted to the frame? I know when I replaced my bumper, the hitch that I put on there stayed in the same place.
Edit: I guess I see in the pic that the receiver is part of the bumper. Mine remain as two separate pieces.
I'm trying to understand how a new bumper makes for a better towing experience. Isn't the hitch mounted to the frame? I know when I replaced my bumper, the hitch that I put on there stayed in the same place. Edit: I guess I see in the pic that the receiver is part of the bumper. Mine remain as two separate pieces.
