Need pics of e-brake cables
It was really late last night when I got a chance to check...but my 4 doors are about 64" from the point they exit the vehicle...I didn't get a chance to download the pics...tonight I promise
Luke 11:9
My cables are 48" (2-door).
Passenger side:
Driver's side:
Driver's side close-up. My measurement was up to the 'hook' the goes thru the 'eye' in this pic. Make sense?
Passenger side:
Driver's side:
Thanks!!!
Do you think the line is flexible enough that if you moved the brackets on the axles up about an inch, the cable would still pull out on the e-brake loop? Or do you think that it would bind up and not pull them out?
The part that feeds into the tub is a lot different than the TJ's though... I'm not sure if that will work. Are there any other connections on the front of the lines where they go into the body, or do you know what they do when they get under the console?
looks like you got some good pics to work with...I haven't removed my console yet to let you know what happens under there
Here's one with a tape measure to maybe help out
