need help fast!! upper control are bushings!!
Old 01-29-2013 | 05:03 PM
  #21
JK08MCS's Avatar
I recently bought stock bushings from quadratec for the front axle upper arms.
Think total was 25$.
Going to replace them soon.
My only problem I see is the locker plug goes into the diff right where the bushing will be pressed out.
I think it was a 8 mm bolt, unthread and just pull the plug up off to the side. That was the easy part of that side.
I really wish I had a cutting torch to burn out the rubber section.
Old 01-29-2013 | 05:54 PM
  #22
rinkishJK's Avatar
That's good to know. I wasn't sure if there was enough extra wire inside the diff on that plug to allow it to get out of the way of the work area.
Quick Reply: need help fast!! upper control are bushings!!
