Nav update
What version is your system software. The MyGig system, not the Nav version..
If you are below 43.xx.xx you can update just like any other Garmin - create the USB with the proper directories and files and it should update. If you system software is newer then it won't work..
What version is your system software. The MyGig system, not the Nav version.. If you are below 43.xx.xx you can update just like any other Garmin - create the USB with the proper directories and files and it should update. If you system software is newer then it won't work..
Hmmm I'm not sure what it is, I'll have to check when I leave work. Thanks for the info
