napa 5w-30w full synthetic oil
Well it must have changed for 2013, it's 5w20, I checked my oil yesterday as I was searching for a head part number and it's clear as day on the oil fill cap. I was thinking where an I gonna find 5 quart jugs of 5w20. Maybe that explains why I'm getting 20.5 mpg on my second tank of gas?!?
Mobil 1 forever.
0-40w Mobil 1 in both Rubi's. Ticking noise down to a minimal can barely hear it. Oil changes at 5000 miles.
Damn they run super smooth with this weight.
To each his own.
Martin
Mine- 2011 blk. Rubicon.
hers- 2011 slvr. Rubicon.
To each his own.
Martin
I can say 20.5 would be sweet to see!!! Might deal with the rattling to get that MPG!!
Originally Posted by nakednuns
The dealer accidently put 5/20 in my wrangler (I have the 3.6) and my engine DID NOT like it! it rattled like someone shaking a Krylon paint can! They changed it back to 5/30 and PRESTO, ran quiet until I had to have the Drivers side head replaced for ticking. LOL
Napa 5w30
Use what the oil cap says to. Keep all the recites,I keep a record of date and milege when changed. be sure whatever oil you use it meets the crysler spec.-6395. No ticking from my 2012. using Pensoil 5w30 dino oil now, will go syn. after 3000 miles.
Originally Posted by genesbro
The first number in the oil weight is it molecular size number and these days if you go with a 10 over a 5 you are most likely going to ruin your engine. The oil passages are designed to very tight tolerances as well as crank clearences. However you can run a 5w-50 if you choose and that would be ok, but probably not a real good idea in a cold climate.
I have Napa full synthetic sitting in my 2012 JK right now. I have about 17,000 miles on the JK and about 2800 miles on this Napa oil. I do 5000 mile oil change intervals not the 8000 like is in the Jeep manual.
I don't like the Napa oil. The engine seems to tap more and the oil smells bad. I am not sure if the smell is due to the oil or a bad head. However, ever other oil change I used 5W-30 Pennzoil Platinum with no issues of loud tapping or bad smells. I will be going back to my trusted oil (or G Oil full synthetic) at 20,000 miles.
I am new to this forum so if I am saying things that have been beat to death let me know. The oil change interval has also changed to 10000 miles or one year for the 2013. The required interval will also be displayed on the instrument panel based on how you drive so it could be less than 10000 and one yr. By the way for you M1 fans, and I am one, M1 does not presently meet the Chrysler spec 8395 or whatever it is as Mobil has not provided Chrysler with the data required. Do to this, and to make sure I keep my warrantee in effect, I plan to switch to Pennzoil Ultra which does meet the spec. With all the Pentastar head problems I don't want to give Jeep any excuse not to repair my engine. I think the issue has been resolved for the 2013's but only time will tell.
i know many of you change your oil much more frequently than the limit Chrysler suggests and I also know many of you do not use synthetic oil. I don't wish to get into that as it becomes a chocolate vs vanilla or manual vs automatic argument to which there is no answer.
