Mystery Rattle
if it seems to be RPM related (shows up at certain points in the range) don't let sound looking heat shield welds fool you. They can be cracked and look fine. Mine was cracked on the lateral run...they replaced the muffler trying to fix the noise and a hose clamp eventually solved it after finding it with a rubber mallet.
Originally Posted by jboth
I just recently fixed a rattle on mine. It was the 2 bolts that held the passenger side of the exhaust pipe into the header. They were loose.
Speaking of play, how much should there be in the front pinion? In other words if you rotate your front driveshaft back and forth, how much slop should be there?
It is normal to move a bit(1/4 to 1/2" or so)
New rattle for me too..under the drivers side in the front. Coincidently it happened after I snapped my e brake cable parking on a hill. Got an arctic blast of air that night so I'm hoping the rattle is from ice buildup..45 degrees below zero for the windchills! I go to the dealer tomorrow so I'm gonna have them look for a rattle!
