My first LSD trip
#21
Where you getting your info? I think this forum needs some references. However, 2007 is after 2006 so i guess I agree.
My build sheet and Jeep say it is an ELECTRONIC LIMITED SLIP DIFFERENTIAL (TRU LOCK). it is a limited slip differential until it is locked. A locked differential is not a limited slip...it is locked. Now I gotta suggest checking out www.jeep.com go to 4x4 basics...lots of good factual information there.
The Track-Lock is the LSD. Jeep only provides us a limited slip in the rear...huh they seem to provide many things to us only in the rear.
Here's more info on it from http://ww w.jpmagazine.com/roadtests/154_0611_2007_wrangler_jk_pros_and_cons/index.html
Complaint: The new electric lockers suck.
Reality: The JK axlehousings, shafts, and gears are all stronger than the TJ's. It's true, when disengaged the rear JK Rubicon locker is open whereas the TJ's is a limited slip. But we'll take the strength and durability over the limited slip any day.
Links disabled JIC.
#22
Lsd
I thought I was on the wrong forum.....
As a marathon runner and Ironman in training (April 13th 2008, Tempe AZ), I thought you were talking about running. LSD (Long Slow Duration) is part of my training, to get longer runs in (over 20 miles). I also do SPEED (shorter, fast runs) too.....
I love my hobbies!!!!!
#23
Finally found it. Electronic Limited Slip is a fancy name for our Brake Lock. Dude your Rubi diffs are open until you lock them. That's the Jeep Tru Lock ref: ww w.jeep.com
Links disabled JIC.
Links disabled JIC.
Your mistaken about what Jeep says, Here is a quote and link for you.
http://www.jeep.com/en/2007/wrangler...ems/index.html
"Standard on the Rubicon is the Tru-Lok system. The Electronic Limited Slip Differentials or ELSD locks power and distributes it evenly so both wheels turn at the same speed for the ultimate in traction. This means more power to the tires that are in contact with the surface where the power is needed the most to carry you over the top..."
It's called "All-Speed Traction Control" when the Jeep adds brake to spinning wheels to transfer torque to the appropriate wheel.
When going to Jeep, make sure your looking at the Wrangler, not the "Quadra-Drive II" on the Grand Cherokee.
#24
Another nickel tidbit that may either help or fuel the debate.
In viewing an '07 Unlimited Sahara with the Limited Slip Diff option, and an '08 Rubi with ESP/eLSD - each having both rear wheels off the ground the following was observed:
The Rubi's tires spun in opposite directions. Meaning if you spun the rear drivers-side tire in a forward motion, the rear passenger-side tire spun in a rearward direction.
The Sahara's tires spun in the same direction. Meaning, spin the rear drivers-side tire in a forward motion, the rear passenger-side tire spun in the same (forward) direction.
I believe this showed me that the Rubi is really a physically\mechanically open diff (and eLSD doesn't kick in until needed) while the Sahara was not a physically\mechanically open diff having LSD available full-time (even if not needed).
#25
#26
Jeeps ESP is a good idea; although its not as aggressive as it should be when it comes to LSD. Toyota has it down packed! A friend has an FJ and he climbed a particularly steep rock inline in 2WD. My jeep had to be in 4WD to climb up.
We went a bit further and he got high centered while I crawled over the hump.....
My point is that LSD via ABS can be very effective. JEEP just needs to make it more aggressive.
#27
There are THREE kinds of differentials available in the 2007 and up Jeep JK. 1). A standard "peg leg" open differential. 2). A limited slip differential. 3). A selective electronic locker. The lockers are only available on Rubicons and some X models that are special ordered. The X models that have the rear locker option also have the electronic sway bar disconnect as the two are part of ONE package.
The "BLD" or "brake lock differential" is a TOTALLY seperate system to SUPPLEMENT the optional differentials explained above. BLD is not a part of the differential. It works through the Jeep's ABS computer by sensing wheel slip and applying that particular brake to help "hold" that wheel from spinning and directing a more equal amount of power to the wheel with traction.
The locker available in the JK is NOT a limited slip when disengaged, like the 2006 and BACK. It is a standard open differential until you flip the switch, then is is a SOLID LOCKED SPOOL.
I hope that helped.
I hope that helped.
#28
I hope that helped.
I hope that helped.
edit to add: Each Tru-Lok diff has 4 spider gears, whereas the others have 2.
#29
My buddies in college would chug Orange Juice because they claimed that Vitamin C enhanced the effects... Was anyone else a retard in college? The best way to tell if it's working.... Go look in the mirror, if you run out of the bathroom screaming hysterically... IT'S WORKING!
#30
I hope that helped.
I hope that helped.
