Motor mount/Tranny mount problem after collision
#21
Mine weren't centered when I was "done". The mount was slid clear to the back and I had to move it clear to the front. I don't think over-torquing is going to be the issue, the rubber needs that torque to do the job.
Regarding your transfer case crossmember- I've taken to jacking it clear up and then tightening it down once it's there, I don't think it's possible to mess it up.
karls10jk (03-22-2021)
#22
This worked like a charm for me.
Genius. I didn’t have a ratchet strap handy so I drove in reverse at about 10 mph and braked hard (my trans had slipped forward) and that slid it back into place. Tightened the bolts and no more vibrations. Drives like new again.
QUOTE=karls10jk;4231846]Loosen those three transmission mount bolts and move the transmission back to where it was and your vibration will go away. It'll cost a few minutes of your time.
I had a similar problem with mine after an accident and I got the same story. They brought in "experts" and couldn't find any problems after two weeks. It took me ten minutes to notice the shifted mount bolts.
So you can loosen those three bolts then use a ratchet strap to pull the transmission back to where it needs to be. I don't recall where I pulled on the transmission but it works. I did a similar pull to reset the mount after pulling and reinstalling the transmission.[/QUOTE]
