Mobil 1 Oil Change Knock
Old 03-29-2015 | 07:03 PM
sarge2130's Avatar
Default Mobil 1 Oil Change Knock
I just changed my oil on my 2011 JKUR with Mobil 1 synthetic 5W-20 extended performance oil and the Mobil 1 extended performance oil filter, and I noticed after driving for a few miles that there is a light knock coming from the engine area when idling, and from what I have researched, I just need to change the filter to one with a better anti-drainback valve. Others were saying to use the Purolator PureOne or the K&N filter instead, but I just need some feedback on what my best option would be.
Also, it was hard to find others with the same issue of knocking with the Mobil 1 filter. Did I just get a bad filter or is it something to expect with the Mobil 1 filters?
Old 03-29-2015 | 07:17 PM
ronjenx's Avatar
The anti-drain back valve comes into play when the engine is started after being off for a while. With no or ineffective valve, the engine will tap or knock for a few seconds while the filter fills up.
Your knocking while idling is probably another issue. Try a heavier oil.
Old 03-29-2015 | 08:13 PM
Sierra141's Avatar
Just get the Jeep one from a dealer, they are cheaper than the ones mention and they work good.
Old 03-29-2015 | 08:18 PM
Ryan0260's Avatar
I would stick with a Mopar filter, and use a thicker oil if the motor is noisy more than a few seconds after startup, like ronjenx said.
Old 03-30-2015 | 05:46 AM
jeepmojo's Avatar
Default any thing i ever put mobil- one synth in
knocked . I wont buy it , others swear by it (not me ) knock knock knocking on heavens door .
Old 03-30-2015 | 06:22 AM
sarge2130's Avatar
The problem I was hearing is actually when the car warms up, and is idling. I had never heard it until after I changed the oil out, and when I drove it today, it was much quieter, and you could only hear it when out in front of the jeep, rather than hearing it inside and out.
Old 03-30-2015 | 06:38 AM
sarge2130's Avatar
what do you think I should use synthetic-wise, as well as the filter? mine's been on synthetic for a while but it was the dealership free oil changes with synthetic.
I originally chose Mobil 1 because of everyone online swears by it....
Old 03-30-2015 | 07:29 AM
ronjenx's Avatar
[h=2]any thing i ever put mobil- one synth in[/h]knocked . I wont buy it , others swear by it (not me ) knock knock knocking on heavens door .
At the other end of the spectrum, I've been using it for decades and never had an engine knock.
Old 03-30-2015 | 07:30 AM
ronjenx's Avatar
As suggested above, go to a heavier oil; 5W-30.
Old 03-30-2015 | 07:31 AM
Tackle Box's Avatar
Interesting...
I changed my suburban oil to Mobil 1 extended life and she knocked at idle as well. As others have said, probably use heavier oil and it will go away. I will be putting regular Mobil 1 into my JKUR for the first time this week - hoping it works quietly. Too expensive to drain out good Mobil 1 and recycle it!
