Mobil 1 Extended Performance (EP) Oil and Filters
Coming up on my first oil change for my 2011 and wanted to know if anyone has switched to or is currently using the Mobil 1 EP oil and filter combo...I was going to try to push my oil change intervals out to 4k to 5k instead of 3k.
I was going to start with Royal Purple, but decided that Mobil 1 may be the better choice for me since its more readily available.
Not trying to start a debate on the which oil is best because I know that like asking about politics and religion.
Thanks...
Thanks...
research oil filters on here - there are many, many threads about why not to use Mobil 1 filters. I had put one on, read the forum, and changed to the Motorcraft FL-400S 3 days later.
BTW: You shouldn't compare oil choice to religion and/or politics. A better comparison is beer. Beer is a matter of opinion. Religion is something too personal to touch. Politics is a matter of those slightly left of center, and those in the wrong.
I have 100s of thousands of miles on Mobil 1 filters. Never a problem. And I believe that petroleum engineers are better at assessing the performance possibilities of oil and filters than anyone else. I run my oil a year (but I'm out of warranty). I change it earlier if I run it in especially dusty climates (such as after three days on White Rim Trail). I've always run Mobil 1 for a year--ever since the very early 80s when I switched to it from dino. I know, that's heresy. 3K miles or your engine will die. None of mine have, yet, and my longest life vehicle is at 160K miles.
Careful. Some in the crowd regard their beer with religious fervor, too.
Newbiejeeper is pretty much right. Any discussion of oil type or change schedule triggers knee-jerk reactions of what should and shouldn't be. Mostly based on what someone was told or how its always been done.....
Can't we all just get along? (President Dale/Jack Nicholson)
Thanks...
Thanks...
I have been using the M1 EP in 5w30 for the past 10k miles or so with 5k change intervals & will continue to do so.
I usually buy the filter at an auto parts store but I buy the M1 at walmart in the gallon jug for around 25 bucks or so.
Good oil & good filter. No problems to report. Recommended.
Personally I'd stay away from the Royal Purple as I think the purple dye is an unnecessary marketing gimmick.
Just my 2 cents...
