Mobil 1 dry starts
#21
Jack, the best way to tell is after your Jeep has been sitting a day or two. Get in and turn the ignition to the "ON" position. Let all the lights cycle off. Make sure accessories like the radio and A/C are all off so you can hear. While watching the oil light and listening to the engine, start it up. If the oil light comes back on, even for an instant, chances are your anti-drain back valve in the oil filter is not working properly. In some cases, as outlined in this thread, you can even hear the rod bearings clatter for a split second on startup. So far, I've found that WIX filters work very well. Others have had luck with other brands. I don't think there is one filter in particular that is a sure fire fix. You just kinda have to swap around until you find a good one.
#24
I had mobile 1 oil filter on my jeep for about half a day. They don't seem to work on our vehicles. I swapped to a Fram Tough guard and the startup noise went away. I will never use the filter again.
#25
For some good info about filters read this:
http://www.knizefamily.net/minimopar...reference.html
It shows what is what and why no self respecting car/truck person would run Fram on anything they actually want to keep running.
#26
I had this exact same problem! wow it took quite a while for us jeepers to post up on this! I am going back to a mopar filter tomorow! Mine has a rough sound for a bout 1 sec and then goes back to normal. The oil pressure light also comes on and then turns off the same time the rough sound stops. My question is will this cause long term damage? will is decrease the effecency of my engine?
#27
Long term peice of mind and Fram do not belong in the same sentance.
