manual transmission problems
went to start up my jeep today and it was in gear. as i turned the key the jeep started but jumped forward like it wanted to go and was making a weird rubbing noise. i then tried to get it in neutral and it wouldnt let me. so i shut it off and it shifted fine. started it back up in neutral and couldint get it into any gears. had to shut it back off and start up in 1st and pretty much force it in every gear so i could get home.
is my clutch toast?
2007 jku with 52k miles
thanks so much
nathan
is my clutch toast?
thanks so much
nathan
is my clutch toast?
thanks so much
nathan
is my clutch toast?
thanks so much
nathan
It's a hydraulic actuated clutch, I'd bet the problem is related to the master/slave cylinder. Search, and you'll probably find some similar symptoms.
Edit -- just saw the weird tapping noise mentioned, and the hydraulics's won't cause that.
its happened a couple months ago and finally after a couple days of shitty driving and hard shifting it corrected on its own for several months and now back at it again
wonder if i should bleed the clutch first and see if that helps?
Update..went back out and started it up and it drove perfect and shifts perfect...just still has that same ticking noise...I made a video of it so maybe someone can pinpoint the problem for me...the noise stops every time I push or just rest my foot on the clutch pedal
IMG_4888_zps179f4721.mp4 video by 98dropta | Photobucket
