Lube points for the JK
I have read the thread about the steering lube points and I think I can find them all but is there other points on the body/suspension that need to be lubed with either grease or some other lubricant?
Any ideas will be greatly appreciated as I have purchased the needle for the grease gun and plan to use it tomorrow.
Colt
Colt
well a couple of areas on the body of the jeep would be the hinges to help keep the pin inside from rusting.
And the 12 windshield bolts 6 on each side. Behind the bolts I notice it started to rust, so I removed each bolt one at a time and cleaned up the small trace of rust and sprayed alot of rust lubricant and the bolt and reinstalled each bolt. And I respray when needed.
I have not seen any rust signs on my windshield bolts but I have noticed that the paint on them was chipped when I purchased the vehicle. I will check those when I am lubing.
Another thing people often don't lubricate is the zippers on the soft top. It'll make a big difference if you don't lubricate them after awhile -- at least that was the experience on my TJ.
The Owner's Manual has a lot of good information on what to lubricate.
I'd like to see a "lubricate here" chart showing all of the Zerk fittings. Does anyone have a chart of all of the fittings on the JK? Would be nice to know where to look instead of hunting them down. Seems like I always miss one.
