Lots of lights in dash and codes
2010 Jeep Wrangler Islander
All lights on in dash ABS, E-brake, Traction control, Engine, Temp gage reading is wrong, ESP, Gas Gage don't work, Speedometer don't work. Replaced fuel unit in tank, replaced all wheel sensors. Xtool diagnostic won't clear the codes. Had PCM checked. Battery tested good (put battery charger on and no change) Scanner shows no speed signal to wheels and displays silly speed, Speedometer states 511kmh while sitting still.
Any help would be greatly appreciated.
Codes:
P0463 Fuel level sensor 1 circuit High
P0073, Ambient Air Temp Sensor High
U1412, Implausible Vehicle Speed Signal Received (511kph)
U1417,Implausible Left Wheel DistanceSignal
U1418, Implausible Right Wheel DistanceSignal
P0158, O2 Sensor 2/2 Circuit High, (new Sensor)
P0138, O2 Sensor 1/2 Circuit High (new Sensor)
P0152, O2 Sensor 2/1Circuit High (new Sensor))
P0132, O2 Sensor 1/1 Circuit High (new sensor)
C100A, Left front speed sensor Circuit (new sensor)
C1015, Right front speed sensor Circuit (new sensor)
C1020, Left Reart speed sensor Circuit (new sensor)
C102B Right Rear speed sensor Circuit (new sensor)
C2200 Anti-lock Brake Module internal
Codes:
