Lost almost all engine compression overnight?!
#32
Right, it is a chain running on sprockets and is expected to last around 200,000 miles but they do stretch and do have a finite life. He isn't far from half life, since I am keeping mine for life I would choose not to go back in to it 5 years on but move that out to ten to twelve years. Again, only because he is already in there and just something to think about.
#35
Another update:
Assembly should have started on Saturday but I ordered new connecting rod bolts (since they're single use) and I was supposed to receive 12 but only received 1. As of now, I can't do anything further until I have the new bolts. It has given me a little more time to clean clean and clean some more. If anyone would like to double-check my work and make sure I haven't forgotten any steps that would be great! I will list the parts and what I've done to them:
Heads:
Cleaned mating surfaces
Lapped Valves
Replaced seals
Checked seals with water
Cleaned all passages thoroughly
Block:
Checked end gaps on new rings
Honed cylinders (checked end gap before and after)
Pistons:
Cleaned all carbon off
Installed new rings
Double-checked new rings are installed in correct direction
Inspected bearings and cleaned surfaces
Replacing rod cap bolts
Lower Intake:
Exhaust:
Replaced with headers and wrapped w/ exhaust wrap and coated with protective silicone spray
PCV valve was replaced recently and I don't plan on replacing my EGR valve until something happens to it (It's not too difficult to access if I need to replace it in the future.)
I'm sure there's more I've done to it but I'm probably forgetting some of the stuff. If anyone would like to chime in and double check anything to make sure I haven't missed any steps that would be great! I've checked clearances on just about everything but there are a few things I can't check just because I don't have the proper tools. I'm really rolling the dice on the things I can't check, but the engine was never overheated and so far all the clearances I can check have been spot on. Honing doesn't look as good as I was hoping (this was my first time honing). The pictures tend to make it looks really rough and too steep of angles but all the marks are about 60 degrees.
Couple more pictures I took...
Heads:
Lapped Valves
Replaced seals
Block:
Pistons:
Installed new rings
Lower Intake:
Exhaust:
#36
Nice work, like the can-do attitude! I'll bet that that engine ends up running well. Interested in how those headers work out too.
From reading your first post, I can't help but associate the sea-foam with the sudden compression loss. Granted there was probably already a ring sticking problem, but maybe too much dissolved carbon & varnish went into the ring grooves, and when the engine cooled the rings became severely stuck. It's a commonly used product, but weird stuff happens sometimes.
