Loose Hood, Dealer NO help!!
Old 11-05-2008 | 07:12 AM
  #21
justinstoffregen's Avatar
Originally Posted by robin
if you're an engineer that works in aerodynamics you could probably have an extremely long answer of why the air dam is there, and also why is so important to have it, but if you're one of the guys like me, and others, I would tell you to get rear of it doesn't do anything, probably up to 90% or more of the mod jeeps in this forum don't have it, (its worthless)
Well, it's not worthless, but it's not a big deal to not have it. I think if it was worthless DC would've left it off to make out JK's even cheaper than they are.
  #22
pearl-drum-man's Avatar
I put 5K highway miles on my JK last year on a long vacation, mostly on two-lane roads. We had a ton of hood dancing. With the air dam. The air dam doesn't do a damn thing to stop the hood shake. Two 14" Zip-ties, however, have stopped it absolutely 100%, and cost about fifty cents:
I also had hood lift with the air dam, I do think it's possible that it could be even worse on a JK without it though. Who knows without empiricle test data though.
Old 11-05-2008 | 07:18 AM
  #23
Littlejon's Avatar
I had the same issue. Took off the hood spring and it is fixed. It is completely normal to have the hood flutter, and there is nothing Jeep or a dealership can or will do about it since the only options are taking off the spring, using a zip tie, or using the Day Star rubber pieces.
Old 11-05-2008 | 10:28 AM
  #24
BigEarl's Avatar
Here's another fix that I stumbled across a few weeks back. I bet if you combine all the little fixes it'll for sure eliminate the problem.
https://www.jk-forum.com/forums/show...ight=hood+lift
Old 11-05-2008 | 10:35 AM
  #25
guinnessisgood's Avatar
Originally Posted by w squared
Zip ties. Works like a charm. Did the fix at a service station after getting some pretty good hood wiggle driving through the Crowsnest pass.
This worked great for me also. I can still open the hood with no problems and once closed it doesnt bounce at all. Spend 2 bucks on zip ties and everything is better. How can you beat something that works great and is super cheap?
Old 11-05-2008 | 02:16 PM
  #26
rickc309's Avatar
I had the same problem, zip ties cured it but I never liked the look. Tried the Daystar straps. Problem solved.
Old 11-05-2008 | 02:37 PM
  #27
AlmightyCrash's Avatar
the aftermarket urethane replacement latches work perfectly!
I put them on the second week I had my JK.
My hood would travel around 1.5-2 inches on the highway....now nothing.
Old 11-05-2008 | 05:31 PM
  #28
Bayrat's Avatar
I did the Jeep brand bug deflector and that took care of most of it but I do still get a little lift once in a great while in severe wind and a truck passes me.
Sooo, my Hood Wranglers showed up today along with my spare tire cover. Now I need to figure out how to break those pins off and replace them.
The tie wrap worked well until one broke in half. It had been on a couple of weeks. Probably cheap Chinese crap.
Old 11-05-2008 | 05:55 PM
  #29
[QUOTE=Bayrat;776010]
QUOTE]
grab both sides of the pins with pliers or channel locks.
Twist.
thats is.
watch out for your paint.
Old 11-05-2008 | 06:02 PM
  #30
Bayrat's Avatar
Are you saying a plier on each side, gripping both heads of the pin, or to more or less squeeze them and twist with one plier? Thanks for the tip by the way.
Quick Reply: Loose Hood, Dealer NO help!!
