long cold start up
Old 06-19-2014, 10:16 AM
entalvis's Avatar
when you go to start it, do you just turn the key from off start to starting or do you move to on and wait a few seconds then start?
if you're just going off to start, try the other way which will give the fuel pump time to push fuel back up and may be a good indicator of whether you are losing pressure at the fuel rail over time (which could be the pump itself). I would turn to on, count to 5 then turn it over and see if it fires right up or not.
Old 06-19-2014, 10:31 AM
mountain pee's Avatar
I have tryed that and it doesn't react different. It still takes a while to start
Old 06-19-2014, 11:30 AM
Jiblet's Avatar
You had the same problem before changing the plugs? What kind of plugs are in there now?
Old 06-19-2014, 02:40 PM
marcusjames2's Avatar
I have the same problem on my '07, but there is no pattern to it. It just does it whenever it feels like it. I know it's not the fuel pump cause I've replaced that. I figured I would just deal with it when it decides not to start one day.
Oh and I should mention that it's done that the whole 2 years I've had it. I bought it with 87,000 miles and now have 119,000.
Old 06-21-2014, 05:56 AM
Crap I can't remember what I bought. I bought them from advance auto and I believe double platinum. I asked for the best ones but I know that doesn't always mean anything.
Old 06-22-2014, 10:52 AM
rizob's Avatar
Had this problem with my 2011. Intermittent long crank. Which progressively got worse to the point where it wouldn't start for days. Then it would start.
First dealer told me it was either the pcm or tipm and would cost a million dollars. Decided to take it to another dealership and they replaced the fuel pump relay for $99. No problems since then. Check your fuel pump relay.
Sent from my SCH-I545 using Tapatalk
Old 06-22-2014, 11:47 AM
Jiblet's Avatar
Originally Posted by rizob
Had this problem with my 2011. Intermittent long crank. Which progressively got worse to the point where it wouldn't start for days. Then it would start. First dealer told me it was either the pcm or tipm and would cost a million dollars. Decided to take it to another dealership and they replaced the fuel pump relay for $99. No problems since then. Check your fuel pump relay. Sent from my SCH-I545 using Tapatalk
Fuel pump relay thread:
https://www.jk-forum.com/forums/jk-e...-relay-274779/
Old 06-22-2014, 02:02 PM
Awesome I'm really hoping that's it. Thank you for all the sugestions
Quick Reply: long cold start up
