Limitations Stock Sahara
As i am new to Jeeps (2 weeks), I was just wondering what the limitations of a stock Sahara Unlimited is on the trails.
What can it do in Mud, water, Rocks, beach... etc.
How much flex does it have? Etc.
Thanks
-Evan
Thanks
-Evan
Also might want to check out some youtube videos as sugested lots of em show you what not to do!
Air down your tires to about 15 psi and disconnect your sway bar links, and you can do all of the above. Height (clearance) will be more of a limiting factor. I've heard of some Rubi's eliminating their e-discos and replacing them with quick disconnects, claiming to get more flex with the standard sway bar, and disconnecting it (not speaking from personal experience, just what I've heard).
When my two door was stock and not lifted yet it could still do all of the same trails as it does now with the lift. But there was usually a little bit of skid excercise, and some stressful spotting situations.
You will definitely be amazed, as i have also been, at the capability of a stock JK.
What gears did you end up with? Do the saharas come with 3.73s or 4.10s? Or does it have something to do with a "towing package" or whatever
Here is my jeep when it was stock...
It did pretty well for the most part in most places I wheel. Stock tires are not good in the mud though
http://www.youtube.com/watch?v=kGYTeZQc1V8
Stock Saharas disconnected and aired down will surprise you with their capability. You do not need to spend a bunch of money to get started. It will definitely go and do more than you are probably ready for if you haven't wheeled before.
Don't worry too much about your gear ratios offroad either. Most Rubis will be in second or third on 4Lo (depending on obstacle) and you will be fine on your transfer case in 1st gear. I have the dreaded 3.21s and get along fine. Some rubis complain that the 4:1 is actually too low for mud and sand.
If you don't want to do too many mods....buy more agressive tires and if you want good bang for your buck...get the teraflex quick disconnects and you will be all good to go! That's what I started with and started building from there.
You will be suprised what your JK will do! It's amazing!
