Lifted or not?
Old 12-28-2013 | 02:45 PM
karls's Avatar
Originally Posted by Ncb
With stock bump stops and flares a 33" tire is the largest tire you can run without any rubbing.
35's, aftermarket bumper (or trim the factory air dam) and zero lift, zero extended bumpstops. The op said street machine and it's what I had.
Old 12-28-2013 | 04:26 PM
metaldemon's Avatar
Looks like leveling pucks in the front.
Old 12-28-2013 | 04:57 PM
Jeepstin12's Avatar
Can you post a pic of the body mounts and the rear spring upper seat? With the two pics you have, looks like a leveling kit (spacer in the front only). The rear still looks stock. And the bumpers do look too close to th body for a body lift.
Old 12-29-2013 | 07:38 AM
jtphoto JK's Avatar
Judging by the height in the back I would also say this is no more then a leveling kit. You could run a 285 or 305 but you still will need wheel spacers or offset wheels so the tires don't rub up front when you turn.
Old 12-29-2013 | 08:06 AM
Garrett J.KU's Avatar
2x on this, theres definatly a puck spacer in there and it looks like an extended bump stop. Go with 35 if your fillin the gap up
