Lift & tires affect tow capability?
As you can see from my avatar, I tow a heavy toyhauler. When fully loaded it i about 4500 pounds. All precautions are taken (dual axle brakes. Brake controller. Load dist hitch. Sway control. Safe driving speeds). My question is, when its time for new tires can I consider a lift and bigger tires or will it degrade my towing experience? 2012 JKU manual trans. 3.73 rear with max tow package. Currently running rubi takeoff tires. I just got back from a 700 mile round trip towing the trailer. It does fine, but I would not want it to get worse in any way.
1 Post
Actually, the owners manual max tow says 3500 for a JKU with tow pkg.
In Europe the same configuration is rated at 5k (iirc). Go figure. You could probably get away with it BUT.... if you do get into a wreck, even though the other guy could be drunk, driving down the wrong side of the road with a blindfold on throwing strippers out of the trunk & you could still be liable simply because you were well over the vehicle manufactures recommended tow limit.
I tow a 3000 tent trailer with a JKU Sahara with tow pkg, 6 speed 3.8 engine, with a 2.5" TF lift, spidertrax spacers just fine. I don't like doing it too much but yes, I have taken it over the mountain passes.
I have also towed a 2500lb race car on a 1200 lb tandem axle trailer. Again, it did okay but I wouldn't make a habit of doing it across country anytime soon.
I'd buy a ford turbo diesel if I did
Here it was with factory 18" rims with 32.3" duelers
And the car... With 2.5" lift. Ps... I also had installed a professional grade brake controller system fwiw...
From rear...
Thank you. This is the type I response I was hoping for. I am we'll aware of the rated capacity. I am also well aware of the higher rating for the exact same vehicle in other countries. I am also aware that the jeep liberty is rated for 5000 pounds even though that is lighter, narrower, shorter, and less powerful than the JKU. I have now towed my toyhauler over 4000 miles. Tows fine, I just don't want to degrade the experience any and want to keep that in mind when it's one to get new tires.
I agree with the previous poster... re-gear!
I have been towing my travel trailer for almost 2 years now, dry weight 3,000 lbs, and with stock tires and 4:10 gears it was pulling like a champ. As soon as I went to 33" tires, I lost ALOT of power. It's especially noticeable while climbing. Where I used to maintain 55 mph on a 6% grade, I now barely manage to keep it above 40 mph.
Oh, and I'd recommend a trans cooler too if you haven't already added one. The Superchips tuner with tow setting sure is a nice addition as well.
1 Post
Ahhhh, no worries. It's great that you are well aware. Just a nod of warning from experience however, I have owend my JKU for nearly six years with many more towing miles than 4k.
I have had to replace rear gears, differential carrier, throwout bearing, clutch.
Please understand that the oem parts/ components of a JK towing are a bit on the chinsey side. The stuff just isn't HD enough. 4k+ is a lot of weighty for the vehicles components. You surely do not have to take my well earned advice of experience but I just wanted to throw it out there. Be safe
